AIKO
You can use our plugin to insert the presentation text you wrote in the bastri service.
online documentation
Example: fun
This team was not found in the list of teams INRIA, contact the search direction or disable this plugin.
You can write want you want/need on this page by using HTML tags in the text editor or use the visual editor.
Overview
enter a brief description here.
Research directions
  • item 1
  • item 2
  • item 3
